If you are thinking of keeping your battery charged by connecting a solar panel to the battery, be aware that you may be putting yourself at risk from a fire. The diode on the solar panel is supposed to prevent any back current flowing through the solar panel, however this failed on a friends yacht and caused a large current to flow through the small wires leading to the panel. The upholstery is singed, but fortunately, the foam was fireproof. Nevertheless, a hole was burnt into the battery casing and only prompt action prevented a major disaster. If you do intend to use a solar panel (or indeed any other electrical item connected across the battery terminals), make sure it is fused.
Be aware!
Chris W
Fire caused by Solar Panel
Can I just add to that, it's not just the presence of a fuse that's vital, it's having one of the correct value. It's surprising how many people still think it's alright to fit a higher rated fuse because the lower rated one blows. It blows for a reason and that reason needs to be found, please don't just use a higher rated one, it's asking for trouble.
Thanks for the info though, worth watching for that diode
Come on over to the best place to buy and sell your boaty bits www.sailroom.co.uk
